Experience Re-Tapping a Steam Radiator Air Vent Hole?
I have hot water steam radiators with 1/8″ air vent valves. Upon going to replace one of the air vents I discovered that the threads on the the famlae portion of the radiator itself are stripped and it subsequently stripped my new vent upon trying to install. I would assume the threads need to re-tapped and am looking for any guidance on the process. I think that drilling out with a 7/16″ bit and then re-tapping with a 1/4″ x 18 NPT tap woiuld create appropriate new threads. I think I could then insert a 1/4″ to 1/8″ reducer bushing to fit the 1/8″ air vent. Does this sound appropriate? Appreciate any guidance!
nalusurf
in Plumbers and Plumbing 13 years and 2 months ago
nalusurf | 13 years and 2 months ago
object(WP_User)#5043 (8) {
string(6) "176812"
string(8) "nalusurf"
int(176812)
Thank you all! Probably not a bad idea to begin to gather a few taps of various size…I am sure they will come in handy at some point!
Master Plvmber | 13 years and 2 months ago
object(WP_User)#5042 (8) {
object(stdClass)#5041 (12) {
I’m with pig-three’s suggestion, though the first answer is correct too.
pigthree | 13 years and 2 months ago
object(WP_User)#4990 (8) {
object(stdClass)#5038 (12) {
string(5) "14451"
string(8) "pigthree"
string(13) "pig-three-2-2"
string(9) "pig three"
int(14451)
plans sounds fine. you could also try to run a 1/8″ tap into the hole again to see if it will correct the threads before you drill a larger hole.
ejalbk | 13 years and 2 months ago
object(stdClass)#5044 (12) {
string(5) "32884"
string(6) "ejalbk"
string(34) "$P$Bg/XU2MACGInwaK.txGLMic1qnLU.h."
string(6) "ejalbk"
string(19) "neverafee@gmail.com"
string(21) "/forums/users/ejalbk/"
string(6) "ejalbk"
int(32884)
I believe they make 1/4″ valves so you can probably even dispense with the bushing if the air valve was stripped and needs to be replaced anyway. Your plan seems fine to me….
