I need to hang a shelf
http://cdn.brownstoner.com/519f65b060c7a-.jpg
I need to hang a shelf but it’s on an outer wall that is plaster over concrete, the drill bit stops about 1/2 of an inch into the wall and nails bend there as well.
handymanjoes
in Handymen and Odd Jobs 12 years and 11 months ago
Goatcrapp | 12 years and 11 months ago
object(WP_User)#5140 (8) {
  object(stdClass)#5095 (12) {
    string(6) "108904"
    string(9) "Goatcrapp"
    string(9) "goatcrapp"
  int(108904)
Painter Pete, I just use my hands – takes out all ambiguity.   Regards, Dave the Decorator. Not to self – never hire Handyman Joe (or at least check out online forums to see whattype of advice he’s getting for my jobs, LOL) As to the actual question: i’ll second the tapcon vote. comes with the masonry bit sized properly to the screw, and if you don’t have a hammer drill – it’ll still work for you but the bit will be toast in short order. depending on the fastening method you’re using, you could use the tapcon screws with washers to fasten a wooden header or full backing board, and then build off of that, or you can attach individual shel supports directly with the tapcon screws.
juanus_superbus | 12 years and 11 months ago
object(WP_User)#5139 (8) {
  object(stdClass)#5138 (12) {
    string(6) "177147"
    string(15) "juanus_superbus"
    string(34) "$P$BNLe/KPb5d.tihBQgbdYC9H5NTFnwm/"
    string(25) "juanus_superbus@yahoo.com"
    string(30) "/forums/users/juanus_superbus/"
    string(19) "2017-08-10 14:25:59"
  int(177147)
Hammer drill and lead anchor.  Problem solved.
BobMarvin | 12 years and 11 months ago
object(WP_User)#5135 (8) {
  object(stdClass)#5141 (12) {
I’d suggest using a masonry bit and  long lead anchors that go through the plaster well into the concrete. You may need something more powerful than a small cordless drill to do this.
Master Plvmber | 12 years and 11 months ago
object(WP_User)#5142 (8) {
  object(stdClass)#5143 (12) {
I don’t understand. You’re “Handyman Joe” and you’re on Brownstoner asking how to drive a nail into concrete?
dnk | 12 years and 11 months ago
  object(stdClass)#5144 (12) {
    string(5) "46107"
    string(3) "dnk"
    string(34) "$P$Bc/fuQ6M6AurKgSr2TPjNRasEkYaWi1"
    string(3) "dnk"
    string(28) "dkeegan@laskerfoundation.org"
    string(18) "/forums/users/dnk/"
    string(19) "2017-08-10 13:36:02"
    string(3) "dnk"
  int(46107)
What about one of those blue Tapcon anchor/screws?   You can often buy them with packaged with the proper-sized masonry bit which will take care of your concrete problem.
