Converting Cellar to Basement
Hi – a C of O question. Am in process of buying a legal 2 family in Prospect Lefferts. The C of O lists a cellar. I’d like to convert it to a basement to increase the legal occupancy space. Any advice on how hard this is to do? And a related question – if I manage to convert the lowest level to a basement, what would I have to do to make the basement the 2nd unit, so I can take over the ground and second levels? Thanks for any advice!
sarahplg
in About Brooklyn 11 years and 8 months ago
nancyk | 11 years and 8 months ago
object(WP_User)#5011 (8) {
  object(stdClass)#4973 (12) {
    string(6) "181896"
    string(6) "nancyk"
    string(34) "$P$B8reto1VXYVBkZV9tFTY6URgmXmjP3."
    string(6) "nancyk"
    string(23) "nancykourland@gmail.com"
    string(19) "2017-08-10 14:09:32"
    string(6) "nancyk"
  int(181896)
with a title company. i used ridge abstract, which is located in brooklyn. the cost was $150.
arch007 | 11 years and 8 months ago
object(WP_User)#4989 (8) {
  object(stdClass)#5010 (12) {
    string(5) "29788"
    string(7) "arch007"
    string(7) "arch007"
    string(16) "master@gmail.com"
    string(7) "arch007"
  int(29788)
How do you file the restrictive covenant?..and cost?
jockdeboeraia | 11 years and 8 months ago
object(WP_User)#4990 (8) {
  object(stdClass)#4988 (12) {
    string(5) "40876"
    string(13) "jockdeboeraia"
  int(40876)
There is always a way, but you need to have the FAR available and special permission to do it.
  object(stdClass)#5012 (12) {
    string(6) "181896"
    string(6) "nancyk"
    string(6) "nancyk"
    string(6) "nancyk"
  int(181896)
Your cellar can never be a living space, i.e., no one can sleep down there. You can turn it into a family room/rec room. You may also put a full bath down there so long as you file a restrictive covenant that states you will not use the cellar for living space. I just did this, so I am aware of the DOB rules. Hope this helps.
lmtuzyjcftvgonr | 11 years and 8 months ago
  object(stdClass)#5013 (12) {
    string(6) "209468"
    string(15) "lmtuzyjcftvgonr"
    string(34) "$P$BW0FXx0gVSJiLPKEyhXA8jen32TaEk."
    string(16) "bboz36@gmail.com"
    string(19) "2024-07-01 11:22:35"
  int(209468)
As for CofO, you cant “legally” increase it. Because a cellar by definition will prevent you from doing so.
object(WP_User)#5012 (8) {
    string(6) "209468"
  int(209468)
You can never convert a cellar into a “legal” living space, or to a basement. Due to the following definitions: •A basement is a story partly below curb level but having at least one-half of its height above the curb level. • A cellar is an enclosed space having more than one-half of its height below curb level. Therefore, your best bet is to excavate the cellar (if necessary). Achieve a comfortable ceiling height (min 7′), and as for as dept. of building should be concerned it is just storage space/entertainment area. With an experienced designer and contractor, this isn’t as difficult as most people find it. We have personally completed a similar renovation for a client. Mosfigul Aktar, Assoc. AIA Architectural Designer Construction Manager Phone: 917-495-6775 Email: info@aktargroup.com Website: www.aktargroup.com
mrohrmann | 11 years and 8 months ago
  object(stdClass)#5240 (12) {
    string(6) "177226"
    string(9) "mrohrmann"
    string(34) "$P$BQ2EBBkfg/UC.iWtUOGEUE4nJfq88P1"
    string(19) "mrohrmann@gmail.com"
    string(24) "/forums/users/mrohrmann/"
    string(19) "2017-08-10 14:26:01"
  int(177226)
Depending on the depth below grade you cant change it, but you dont have to to use it as living space. You can finish it for a rec room or something like that, you just wont (legally) be able to put a full bathroom down there or have someone live down there full time.
