Chris Dinapoli, General Contractor: Think Twice Before Using
**Chris Dinapoli and his team were responsible for the renovation of our Sunset Park Brownstone in 2011\. They did a decent enough job with heavy lifting tasks such as framing walls, drywall, plumbing and electrical. But the team cannot be trusted with anything beyond that. Having lived with their work for over a year now, I feel compelled to urge home-owners to think twice before working with Chris.
Below are some key issues we faced with their work. Our biggest complaint however is that, on the whole, when confronted with our issues, Chris either lied to us, evaded our questions, or tried to change the subject and remind us how he had in some other way “hooked us up.”
Here is a snapshot of issues:
– Street-facing walls and window-boxes were built and installed without insulation, so those rooms in winter are ice cold and in all seasons are noisier than they should be. We were not even consulted about this choice, it was just done. After a cold winter, we are looking at thousands of dollars and a messy construction job to pump insulation into the walls of three street-facing rooms. At the end of the day, we believe that we should have been consulted on this point before the walls were closed up.
– Major issues with floor installation. Pretty much everywhere his team installed wood flooring in our home has failed the test of time. Boards come loose, nails come up constantly. Our kids cut open their feet on the protruding nails. The nails they used had no teeth. In areas of the house where nails probably should have been driven into underlying joists, it didn’t happen.
– After floors were installed, Chris’s team took a saw to the floor in front of our kitchen sink and cut the boards open to get into the plumbing. This area of flooring was left with gashes from saws, and the boards in this area were left uneven, loose, and will eventually need to be replaced wholesale. Unfortunately, we did not notice this had been done until we moved in. When we asked Chris about it, he denied that his team had hacked the floor open, even though the evidence was undeniable.
– Baseboard molding was installed across the front of a fireplace. Despite numerous requests to remedy this, Chris and his team refused to change it, repeatedly insisting that we had asked them to install baseboard molding across the front of a fireplace.
– A toilet was installed a full 4″ away from the wall behind it, so it kind of floats in the middle of the room. Not a huge deal, but very weird-looking. When asked to move it, we got lame excuses about the location of beams underneath. The correct thing to do was available to anyone with access to google: just find a toilet with a different rough-in.
– Doors were poorly hung and do not open and close easily, no matter what season. Despite his team coming back to try and correct this issue, the doors still do not operate quietly as expected. Door stopper trim was installed incorrectly so that the door closed too close to the stoppers, meaning the paint on the door ended up sticking to the stoppers and peeling off at the contact point. My belief is that his team actually does not know how to install doors properly.
– Grout in bathroom floor and kitchen backsplash are not standing the test of time. Cracks started to develop within the first six months and at this point we will need to re-do much of the tile work.
– Wood trim work is sloppy and mis-aligned. Even simple things like the trim around an interior door look like they were done by someone who simply doesn’t care about quality.
– Paint jobs are awful. The lines where different colors of paint meet are uniformly crooked, looking like they were painted by a child. It’s obvious that masking tape was not used and that his team rushed through this part of the work. When asked about this, Chris essentially said, “looks good to me.”
– Kitchen counter was so poorly installed that we actually had to cut the tops off of some of the cabinet doors in order to be able to open them. When asked about this, Chris blamed the counter-top subcontractor.
This is just the tip of the iceberg. Please think twice before working with Chris and his team.**
yanivnord
in General Contractors 12 years and 10 months ago
yanivnord | 12 years and 10 months ago
object(WP_User)#4990 (8) {
  object(stdClass)#5046 (12) {
    string(6) "177382"
    string(9) "yanivnord"
    string(34) "$P$BYc4wNueEKDDJ2/vTdeODBRYpLNNsf1"
    string(19) "yanivnord@gmail.com"
    string(24) "/forums/users/yanivnord/"
    string(19) "2017-08-10 14:17:45"
  int(177382)
We are not pursuing any formal cases, nor have we ever considered it, because as you all have said we made the mistake of going with lowest bid, and at the end of the day you pretty much get what you pay for, within reason. The rub is that I don’t think we got reasonable quality, not even close. But no laws were broken. We just feel that the shoddy workmanship and rude treatment we got should not go without comment, regardless of what you pay for it, and we wanted to let other potential customers of this GC know what they are getting into. Thanks for the feedback, all. (And FYI, this post comes up very high on google when you query “Chris Dinapoli General Contractor” so I hope that it provides an honest warning and good info from you all for other clients considering this GC.)
stevecym | 12 years and 10 months ago
object(WP_User)#4991 (8) {
OP, the mistake you made was taking the lowest bid and not understanding that when you are dealing with a small contracting firm, the 25% you mention is in fact a lot of money.  It sounds to me as if the contractor had not built money into the job to hire specialized trades where they were needed.  It is his fault and his responsibility – but as  property owner, you are not off the hook; yes, you can sue him and make his life miserable and can complain about him on here (and something tells me the people who read this forum would not hire a guy like him anyway; I have never heard of the guy), but at the end of the day, you have a property that someone (never mind him; it could have been anyone) did work on and some of that work probably should have been filed and most probably handled by licensed trades and I would bet was not; just becuase he is a GC does not mean he can perform the forementioned plumbing and any electric work he may have done;  trades should have done that work (just like the flooring guy should have done the flooring and a cabinet installer should have hung the cabinets) and while he should have told you that and shared with you what he is qualified to do, as property owners, the customers take the ultimate hit if something goes wrong years later and the contractor is out of business or sitting on the beach in Florida.
There is a way to avoid situations like the one you have been through.  I have alluded to it in my reply to mr greenmt:  get three bids from reputable firms and go with the middle bid.  Architects and building professionals come on here all the time (and I am not saying me; I am small potatos – count me out, I am repeating what others say) and repeat that very advice.  Why, becuase to do anything other means you might get someone less experienced or desparate for the job.  I will relay a true story here:  when I was working as a lower level building manager for a big company with multiple locations and layers of management in the facilities dept alone, I was given the project of sourcing a contractor to build a very nice maple built-in display case for the lobby at one of the buildings.  The quotes came in like this 42,000 and 50,000 and 56,000.  I took the quotes to my bosses and put forth the 42,000 quote (notice I am using the word quotes; to use the word bid implies that money is the basis for the selection and the lowest bidder will be chosen; money should not be the deciding factor in selecting a contractor; yes we all have budgets, but it is better to scale the project back and go for quality than take quantity over quality).   To me choosing a quote 8k under the next one was a good deal – we’d save the company 8k on a small job, right?  My bosses would hear none of it.  they made me pick the 50,000 quote on the assumption that the lower number may have trouble completing the job or may have trouble producing quality.  Now, understand something – the men who guided me through this process had been working in real estate management since about the time I was born and have most likely forgotten more than I know.   Had we chosen that lower bid and something went wrong, someone would have gotten in trouble  (and the one we chose did a superb job).
Good luck with getting this all straightened out.  I know its awful; I used to go around and fix jobs that other contractors made a mess of – particulalry with the work at the end when the money was tight and they had to skimp on the final details like the finish wood work (I am a finish carpenter so I have seen a lot of this).  I actually saw so much of this and heard so many stories from customers who selected the contractor because he was their friend’s cousin joey and he had no work or he knew so and so so he was giving them a good price that I stopped doing that kind of work.   The truth is contractors can not afford to cut prices and give people deals – we can not do it; the numbers don’t lie, we can’t.   I did work for my cousins on Long Island over the winter and the first thing I told them when I called was “I cannot give you any deals – you will pay what I would charge anyone else” – but what I did do was give them a superb job, one that I know I can look at when I am sitting a their dinner table and be happy to have done – the quality will last forever while the money they spent paying me my rate has already been forgotten.  For a contractor to cut a price or underbid a job cheats everyone involved including the customer, the customer’s family and the contractor and his family.
Good luck.
Steve
greenmountain | 12 years and 10 months ago
object(WP_User)#5046 (8) {
  object(stdClass)#4995 (12) {
    string(5) "12939"
    string(13) "greenmountain"
  int(12939)
Thanks Tinkers Wagon.  As usual you are a steady hand.  I apologize to Mr Dinapoli.  He is both licensed by the DCA and the DOB, so he also has a Workers’ Comp policy.  I entered his name in the wrong search box.  I am not taking sides between Mr. Dinapoli and OP Yanivnord.  I stand by my overall point about our industry:   If “everybody is cheating” (according to my NYS DOL auditor regarding payroll tax, but even more on comp) than the cost of labor for “full fraud” (no insurance, no taxes) is about 40% lower than full compliance.  Taxes vary a little, but insurance rates are rapidly increasing. My auditor said he does not look at financial records for home improvement contractors because “everybody is cheating.”  He said he and his boss just discuss what contractors should pay for “unreported payroll.”  Contractors are free to hire off the books because (at least in my case) the phony amount of “unreported payroll” was affordably low.  Thus, the price of home improvements is low too.  In this case the OP reported low quality, but I don’t know if what they paid was enough to meet expectations, or if the workers were on the books.  Would OP please let us know if they are pursuing a case and how it turns out.
  object(stdClass)#4989 (12) {
    string(5) "12939"
  int(12939)
I was not able to find a license under Dinapoli or Chris Dinapoli on the city website.  As a “fairly above board” contractor myself, I can not compete with those who do not have workers’ comp or deduct taxes.  Paying in cash is a way to help your contractor commit fraud.  The industry has a lot of this.  Even cpa’s and lawyers have advised me to find ways to generate cash.  It make it harder for consumers to seek recourse when contractors are hiding from auditors and sometimes from authorities trying to collect medical expenses and even wages on behalf of workers.  Good luck.
  object(stdClass)#4988 (12) {
    string(5) "12939"
  int(12939)
Was he licensed by the Dept of Consumer Affairs as required by law?  Did you complain to them? If not, why not?  Or was he registered with the DOB?  Did you receive certificates of insurance?  Does he have a worker’s comp insurance policy to compensate his workers in case of injury or death as required by law?  Does he deduct taxes from his worker’s paychecks as required by law, or does he pay in cash?  Did you pay in cash?  Legal, insured labor including payroll tax cost 40% more than cash under the table.  Were you willing to pay for a contractor who does good quality work and follows the law?  If not, who did you think would pay for the bargain you were expecting?  I am sorry this occurred (again).  Most of the work I do involves removing failed work which came before.  Most of that failed work was recent.  I have a lot of experience in seeing the same sorts of problems over and over, but I don’t know what went wrong in your case.  I also know quite a bit about insurance injustice.  The rules are based on new construction, and don’t neatly fit the home improvement work you describe.  There is blame to go around, but the industry data is wrong.  Nobody even knows the extent of the problem. If you want to hear a different point of view, feel free to contact me through the Brownstoner directory.  – Green Mountain
allans | 12 years and 10 months ago
object(WP_User)#4989 (8) {
    string(5) "27109"
    string(6) "allans"
    string(34) "$P$BWfuMxSA1DD7xfjcKR.qJ1ocmVh4cH1"
    string(6) "allans"
    string(21) "allansuarez@gmail.com"
    string(47) "http://www.brownstoner.com/forums/users/allans/"
    string(19) "2009-03-13 01:21:16"
    string(6) "allans"
  int(27109)
Can you give us any insight why you chose this contractor from the get-go?  Was his estimate the lowest bid?  Did you review any of his previous projects (due diligence) prior to hiring?  Did you speak to his references?
