Painting vs. Staining a wooden deck?
What is the difference? I want to paint the floor of the deck in my yard. Can I just buy exterior paint in Mahogany or Burgundy and paint the floor of my wooden deck? Or do I have to sand it first and then stain it? I’m thinking of using Behr Exterior paint for this DIY project. Does anyone have experience with this brand of paint for exterior? Is there something else you would recommend for painting a wooden deck? Thanks for the feedback.
brooklynhouselove
in Decks and Porches 13 years and 11 months ago
brokelin | 13 years and 11 months ago
object(WP_User)#5057 (8) {
object(stdClass)#5045 (12) {
string(5) "90954"
string(8) "brokelin"
int(90954)
Forget that…it looks like you have the paint like stain on there already…
object(WP_User)#5056 (8) {
object(stdClass)#5055 (12) {
string(5) "90954"
int(90954)
And be careful of paint that is called stain. They sell it for houses with unstained clapboard. But it is really paint, despite the name. google it and read up on it before you go shopping for stain.
object(WP_User)#5052 (8) {
object(stdClass)#5058 (12) {
string(5) "90954"
int(90954)
I prefer Benjamin Moore to most, definitely to behr. Being a local boy originally, ben has the market share here. Having grown up elsewhere, where sherwin, not sherman, williams was more common, I used plenty of it years ago, and at least back then, they had good products, too.
KCorey616 | 13 years and 11 months ago
object(WP_User)#5055 (8) {
object(stdClass)#5057 (12) {
string(5) "29344"
string(9) "KCorey616"
string(9) "kcorey616"
string(17) "KCorey616@aol.com"
string(50) "http://www.brownstoner.com/forums/users/kcorey616/"
string(19) "2017-08-10 13:46:18"
int(29344)
Decks should normally be stained with a “deck” stain. If you definately want to paint it then only use a porch and floor enamel…nothing else! Only porch and floor enamel will hold up but even that will probably have to be re-done in a couple of years. And as a parting thought, never use Behr paint. Forget what Consumers Reports says. I have over 43 years in the paint industry serving mostly commercial clients. The majority of commercial painters use Benjamin-Moore for a good reason…it’s reliable and with a proven track record.
concernedcitizen | 13 years and 11 months ago
object(WP_User)#5058 (8) {
object(stdClass)#5056 (12) {
string(6) "177166"
string(16) "concernedcitizen"
string(34) "$P$BLl2eR52NXq8qq.ofKXYiMri5WqO9j0"
string(27) "peter@methodrestoration.com"
string(32) "http://www.methodrestoration.com"
string(19) "2017-08-10 14:25:59"
string(18) "Method Restoration"
int(177166)
What type of wood is it? Has it been finished in the past?
slopegirl | 13 years and 11 months ago
object(stdClass)#5059 (12) {
string(5) "34682"
string(9) "slopegirl"
int(34682)
also they make paint that is “floor paint” which I assume means something in there to help you not slip. you’d need more of that outside, where things get slippery. if you want it dark, why not try stain and then seal with waterproof wood stuff?
urbanexteriors | 13 years and 11 months ago
object(stdClass)#5060 (12) {
string(5) "21301"
string(14) "urbanexteriors"
string(34) "$P$BynvYd0n5TimUJCs201Gk..GHJFJO7."
string(19) "urban-exteriors-2-2"
string(24) "steve@urbanexteriors.biz"
string(55) "http://www.brownstoner.com/forums/users/urbanexteriors/"
string(19) "2017-08-17 21:36:28"
string(15) "urban exteriors"
int(21301)
I agree with slopemope about not using paint on a deck. When it fails (and it will), you will have a major mess. I use a penetrating oil/stain, with UV protection, on all of my decks. Since you want a dark color, go with a translucent stain, but don’t buy it at HD. I think that Benjamin Moore makes what you need. You need to clean the deck first (if you pressure wash, dial down the pressure), but sanding would give you the best results. Steve
slopemope | 13 years and 11 months ago
object(stdClass)#5061 (12) {
string(6) "161310"
string(9) "slopemope"
int(161310)
i’m not an expert, but I don’t think most paint will last long on a horizontal deck surface. Paint sits on top of the wood, and rain pooling over a period of time will seperate the paint from the wood. Then removing it / stripping it will be a huge PITA. Use something that penetrates, like a stain or stain like product combined with a topcoat sealer. If I were you, i would walk into a sherman williams dealer and get real advice, not rely on the big box “help”. The Behr stains actually performed well in consumer reports tests, right behind sherman williams, but paying a little extra for the advice in your case could be worth its weight in gold.
emily000 | 13 years and 11 months ago
object(stdClass)#5062 (12) {
string(6) "179078"
string(8) "emily000"
string(34) "$P$B8lzrD6uvmULcT/8rl1afbxBsBooPt0"
string(21) "h_emily0715@yahoo.com"
string(49) "http://www.brownstoner.com/forums/users/emily000/"
string(19) "2017-08-10 14:38:13"
int(179078)
I think i don’t know how to paint. But I think u can sand it first and then stain it.
brooklynhouselove | 13 years and 11 months ago
object(stdClass)#5063 (12) {
string(6) "177678"
string(17) "brooklynhouselove"
string(34) "$P$Bb/2q0DPg6am3/ecPknXMwTob1v6I50"
string(27) "brooklynhouselove@gmail.com"
string(32) "/forums/users/brooklynhouselove/"
string(19) "2017-08-10 14:26:57"
int(177678)
Here is a pic of the yard deck http://imgur.com/a/qN0bh
