Does a rear deck constitute a "change of egress" and trigger need for a certificate of occupancy on a pre-1938 house?
We are looking at a brownstone (2 family) with no certificate of occupancy. Not a problem in itself, as far as we can tell. Appears to just be an old (pre-1938) house. But, being an old house, we are going to need to do a fair bit of renovations if we take/get it. We will keep it as a 2 family, but I wondered if anyone has found that the absence of a certificate of occupancy made the permits / approvals / inspections process more complicated? Specifically, we would love to put a rear deck on to give us garden access from the parlour floor, using the garden level as the rental. Wouldn’t be a big deal (I think) under normal circumstances, but my current understanding is that certain events trigger a need to get a certificate of occupancy on one of the old pre-1938 houses, and apparently a “change of egress” is one of them (in addition to obvious things like actually changing the occupancy). Does anyone know whether adding a rear door out onto a deck would trigger a need for a certificate of occupancy on a house which currently doesn’t have or need one? It feels like it shouldn’t, but I don’t expect 100% logic in the labyrinthine world of DOB. That said, I also want to do things by the book (kind hard to pretend a door from the back of the parlour floor was pre-existing). And if this change does trigger a need for a certificate of occupancy, does that mean a whole Type-1 alteration application (which I think is a lot longer/more expensive/more complicated than Type-2)? Any info or suggestions on how to deal with it most welcome!
aussieben
in Decks and Porches 14 years and 3 months ago
aussieben | 13 years and 11 months ago
object(WP_User)#5051 (8) {
object(stdClass)#5039 (12) {
string(6) "177558"
string(9) "aussieben"
string(34) "$P$BR1CyoEws3ohExigb6T3pgUkZ3E0lP0"
string(20) "ben.batros@gmail.com"
string(24) "/forums/users/aussieben/"
string(19) "2017-08-10 14:17:49"
int(177558)
I wish I could, but the sale fell through (read – we got screwed), so never had the pleasure of walking this line with the DOB. Sorry Ben
angelat | 13 years and 11 months ago
object(WP_User)#5050 (8) {
object(stdClass)#5049 (12) {
string(6) "178886"
string(7) "angelat"
string(34) "$P$BBoX5QoYIbs8z2grltuH6VVoqpKDVJ0"
string(7) "angelat"
string(22) "furrykarma@hotmail.com"
string(22) "/forums/users/angelat/"
string(19) "2017-08-10 14:03:29"
string(7) "angelat"
int(178886)
Yes please do tell.
nielbot | 13 years and 11 months ago
object(WP_User)#5058 (8) {
object(stdClass)#5057 (12) {
string(6) "179361"
string(7) "nielbot"
string(34) "$P$BrDonw1VVVwyayMKrPS0bnbiZgZR1u/"
string(7) "nielbot"
string(27) "stephen.j.nielson@gmail.com"
string(48) "http://www.brownstoner.com/forums/users/nielbot/"
string(19) "2017-08-10 14:41:02"
string(7) "nielbot"
int(179361)
How did it go? I’m about to close on a house with a strikingly similar situation.
jockdeboeraia | 14 years and 3 months ago
object(WP_User)#5056 (8) {
object(stdClass)#5245 (12) {
string(5) "40876"
string(13) "jockdeboeraia"
int(40876)
It sounds like he is doing other work and will need to file at the very least an Alt II, I have had DOB ask for a C of O to be created if there was not one existing. I just took on a project for that very reason.
aussieben | 14 years and 3 months ago
object(WP_User)#5057 (8) {
object(stdClass)#5050 (12) {
string(6) "177558"
int(177558)
Thanks all – appreciate the quick feedback. And that makes sense – that change of egress means altering an existing, required exit like a fire escape.
yte | 14 years and 3 months ago
object(stdClass)#5246 (12) {
string(6) "178442"
string(3) "yte"
string(34) "$P$B9i5tdNEVtfRwt9wvpHBRIxYwfhU1P1"
string(3) "yte"
string(31) "yeinhorn@oldhouseinspection.com"
string(18) "/forums/users/yte/"
string(19) "2017-08-10 14:02:33"
string(3) "yte"
int(178442)
This should be an alt 2 filing. Not an Alt 1 which would trigger an inspection and new C/O. You are not adding floor area and the only way you would be modifying egress is if the building were a multifamily (3 or more family) and you were somehow infringing or modifying a firesecape at the rear of the building…..
object(stdClass)#5056 (12) {
string(5) "40876"
int(40876)
There is a great way to do this, but no guarrantee DOB will apporve it. It is always worth doing as it will save filing the Alt I if approved.
