Reframing terracotta dumbwaiter shaft walls.
http://cdn.brownstoner.com/512e357a5a4f0-.jpg
I’m looking for a carpenter who can reframe two interior terracotta dumbwaiter shaft walls with wood studs. I’m on the top floor of a 4 floor apartment building. The dumbwaiter shaft is no longer in use, the shaft above my apartment on the roof was removed, and the previous owners already removed two of the 4 walls of the shaft in order to open up the kitchen some. I am installing a washer/dryer in the location, and need to recess venting/plumbing/electric. To do this, I need studs instead of terracotta. I need to make sure the plates are tied into the old system and aren’t just floating on the terracotta shaft below, that a subfloor is installed where the shaft hole used to be, and that all of it creates the proper fire resistence between the shaft and my apartment. Recommendations?
VTXPatriot
in Carpenters and Woodworkers 13 years and 2 months ago
Contractor | 13 years and 2 months ago
object(WP_User)#5176 (8) {
object(stdClass)#5192 (12) {
string(5) "21609"
string(10) "Contractor"
string(34) "$P$BXeRM7G9DUzcm/Nl0pjiytRgRHE4j01"
string(10) "contractor"
string(23) "johnbfitzgerald@aol.com"
string(29) "/forums/users/johnthebuilder/"
string(19) "2017-08-10 14:18:48"
int(21609)
I use anchors that attach studs to terracotta, its a great firewall but so brittle. When repurposing a dumb-waiter you must do some structural work to the floor and ceiling. 2×4’s and ply won’t cut it. Ideally floor involves steel and a concrete base, there are serious fire issues involved. Not to mention you are putting several hundred pounds of weight on yours. If you like I will take a look at it, John – 917 886 9576.
