found cut joists when we started bathroom remodel
http://cdn.brownstoner.com/4e25b4f786543-.jpg
We start just started what we thought would be a pretty straight forward bathroom remodeling on the parlour floor of an 18′  wide 1890s brownstone (i know, i know) to discover that the installers of the previous bathroom had made major cuts in several joists to run plumbing.  See photo.  We have decided all existing pipes should be removed and new pipes installed _**below**_ the joists.
We are now faced with several choices:
1) screw 3/4 ply over the top of the whole mess and say “hey it worked for the past 50 years, why not the next 50?”
2) sister existing joists with LVL or 2×8 lumber
3) sister joists plus install support beam over 16 ‘ span running perpendicular to damaged joist in ceiling below, in which case we need help calculating beam needed to support floor above and bathroom (no load from top floor) with the least penetration into room below.
Any ideas???
Anyone know an engineer who could help?
THANKS
ojonyc
in Brownstoner Renovation 14 years and 8 months ago
eman134 | 14 years and 8 months ago
object(WP_User)#4986 (8) {
  object(stdClass)#4974 (12) {
maybe it is the vent fron the toilet
object(WP_User)#4985 (8) {
  object(stdClass)#4984 (12) {
but replace all the water supply with copper ..looks like black now…also , why does the drain pitch up?
object(WP_User)#4981 (8) {
those are joists, not beams…zero load a bit of metal track across the cut and all is okay
shahnandersen
object(WP_User)#141293 (8) {
  object(stdClass)#4995 (12) {
    string(1) "6"
    string(13) "shahnandersen"
  int(6)
Never leave a plumber unattended to install something. They will destroy your home.
dancingclown | 14 years and 8 months ago
object(WP_User)#141295 (8) {
  object(stdClass)#141296 (12) {
    string(5) "37150"
    string(12) "dancingclown"
    string(20) "leah.ellis@gmail.com"
    string(53) "http://www.brownstoner.com/forums/users/dancingclown/"
    string(19) "2017-08-10 13:50:13"
  int(37150)
also, you can’t use PVC piping in NYC.  has to be all copper, i believe.
edifice-rex | 14 years and 8 months ago
object(WP_User)#141294 (8) {
  object(stdClass)#141297 (12) {
    string(5) "23133"
    string(11) "edifice-rex"
    string(15) "edifice-rex-2-2"
    string(24) "icanbuilditnow@yahoo.com"
    string(52) "http://www.brownstoner.com/forums/users/edifice-rex/"
    string(19) "2017-08-10 14:06:31"
    string(20) "lUubFDX8BGObY7WFD96e"
    string(11) "edifice rex"
  int(23133)
PS the sistered joists do not have to be full length but it wold not hurt if they were
  object(stdClass)#141298 (12) {
    string(5) "23133"
  int(23133)
If the notches are very close to the bearing wall and are notched on top it is a fairly easy repair because most of the load is in shear. You don’t need a full joist and the top of the joist is in compression so it is much easier than if the bottom was notched, especially near the center of a joist.
So fill the notch with solid wood and polyurethane construction adhesive then sister each side with a full depth, 2×8 or 10 with adhesive, nail every 6″ with 16d nails then 3/4″ SHEATHING, not UL plywood, subfloor on topwith adhesive and all will be well
CGmodern | 14 years and 8 months ago
  object(stdClass)#141299 (12) {
    string(4) "5346"
    string(8) "CGmodern"
    string(34) "$P$BpvYZ3yFzBe3V80e3v7IOUvCEqBU7e."
    string(8) "cgmodern"
    string(19) "jackielnx@gmail.com"
    string(30) "http:///forums/users/cgmodern/"
    string(19) "2017-08-10 14:13:40"
  int(5346)
welcome to the club. butchers/plumbers cut out a major support joist….we had to throw in a column underneath…lucklily we could hide it in the wall during the reno.
daveinbedstuy | 14 years and 8 months ago
object(WP_User)#141298 (8) {
  object(stdClass)#141294 (12) {
What a mess!!!    Typical plumbers handiwork.
Sister the joists.  LVL will work.
pigthree | 14 years and 8 months ago
  object(stdClass)#141300 (12) {
    string(5) "14451"
    string(8) "pigthree"
    string(13) "pig-three-2-2"
    string(9) "pig three"
  int(14451)
Hi,
Found the same in my house.  Replace six joists with similar size salvaged joists from NY timber.
Engineering charts are available on line for new and old timber.  Most old homes in this area used Fir for floor and ceiling joists.
I would say not to go with option One.  But you do not necessarily need an engineer and definitely do not need an architect.
