what to do first: floors, or paint?
i can see the pros/cons to each, but we are painting the walls/ceiling/trim AND having the floors screened. which is better to do first? if we do the floors first, there might be dust on the walls. if we do the paint first, the buffer might scuff the new baseboards. we do trust both contractors to do a good job and be careful of each other’s work, but maybe there is an obvious order here for the best outcome.
clairebear246
Springs | 11 years and 1 month ago
string(1) "1" object(WP_User)#5152 (8) { ["data"]=> object(stdClass)#5140 (12) { ["ID"]=> string(5) "13117" ["user_login"]=> string(7) "Springs" ["user_pass"]=> string(34) "$P$BTLknXuobfkPdh2APXje29kDjduYU8/" ["user_nicename"]=> string(7) "Springs" ["user_email"]=> string(21) "jamie.grubb@gmail.com" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2008-07-16 03:51:12" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(7) "Springs" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(13117) ["caps"]=> array(1) { ["bbp_participant"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(1) { [0]=> string(15) "bbp_participant" } ["allcaps"]=> array(1) { ["bbp_participant"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
I would recommend the floor guy last, that is if the floor guy is careful at controlling the dust. Good floor guys have dustless machines and can make the painting touch ups a breeze. Floors first has a much higher probability of messing up the floors. Either way, there it takes time and $$ to cover the newly done floors before painting, or do a post flooring cleanup and paint touch up. Kind of a wash $$ wise but less risk to damaging the floors.
cate | 11 years and 2 months ago
string(1) "1" object(WP_User)#5151 (8) { ["data"]=> object(stdClass)#5150 (12) { ["ID"]=> string(6) "176696" ["user_login"]=> string(4) "cate" ["user_pass"]=> string(63) "$wp$2y$10$4JNbGAK5cKoEp6kzsYVSBO7oMZphxvnQPCDInpVARCm3B1Dj6U75i" ["user_nicename"]=> string(4) "cate" ["user_email"]=> string(20) "cate@brownstoner.com" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2017-08-10 14:24:59" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(13) "Cate Corcoran" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(176696) ["caps"]=> array(2) { ["administrator"]=> bool(true) ["editor"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(2) { [0]=> string(13) "administrator" [1]=> string(6) "editor" } ["allcaps"]=> array(191) { ["switch_themes"]=> bool(true) ["edit_themes"]=> bool(true) ["activate_plugins"]=> bool(true) ["edit_plugins"]=> bool(true) ["edit_users"]=> bool(true) ["edit_files"]=> bool(true) ["manage_options"]=> bool(true) ["moderate_comments"]=> bool(true) ["manage_categories"]=> bool(true) ["manage_links"]=> bool(true) ["upload_files"]=> bool(true) ["import"]=> bool(true) ["unfiltered_html"]=> bool(true) ["edit_posts"]=> bool(true) ["edit_others_posts"]=> bool(true) ["edit_published_posts"]=> bool(true) ["publish_posts"]=> bool(true) ["edit_pages"]=> bool(true) ["read"]=> bool(true) ["level_10"]=> bool(true) ["level_9"]=> bool(true) ["level_8"]=> bool(true) ["level_7"]=> bool(true) ["level_6"]=> bool(true) ["level_5"]=> bool(true) ["level_4"]=> bool(true) ["level_3"]=> bool(true) ["level_2"]=> bool(true) ["level_1"]=> bool(true) ["level_0"]=> bool(true) ["edit_others_pages"]=> bool(true) ["edit_published_pages"]=> bool(true) ["publish_pages"]=> bool(true) ["delete_pages"]=> bool(true) ["delete_others_pages"]=> bool(true) ["delete_published_pages"]=> bool(true) ["delete_posts"]=> bool(true) ["delete_others_posts"]=> bool(true) ["delete_published_posts"]=> bool(true) ["delete_private_posts"]=> bool(true) ["edit_private_posts"]=> bool(true) ["read_private_posts"]=> bool(true) ["delete_private_pages"]=> bool(true) ["edit_private_pages"]=> bool(true) ["read_private_pages"]=> bool(true) ["delete_users"]=> bool(true) ["create_users"]=> bool(true) ["unfiltered_upload"]=> bool(true) ["edit_dashboard"]=> bool(true) ["update_plugins"]=> bool(true) ["delete_plugins"]=> bool(true) ["install_plugins"]=> bool(true) ["update_themes"]=> bool(true) ["install_themes"]=> bool(true) ["update_core"]=> bool(true) ["list_users"]=> bool(true) ["remove_users"]=> bool(true) ["promote_users"]=> bool(true) ["edit_theme_options"]=> bool(true) ["delete_themes"]=> bool(true) ["export"]=> bool(true) ["NextGEN Gallery overview"]=> bool(true) ["NextGEN Use TinyMCE"]=> bool(true) ["NextGEN Upload images"]=> bool(true) ["NextGEN Manage gallery"]=> bool(true) ["NextGEN Manage tags"]=> bool(true) ["NextGEN Manage others gallery"]=> bool(true) ["NextGEN Edit album"]=> bool(true) ["NextGEN Change style"]=> bool(true) ["NextGEN Change options"]=> bool(true) ["email_users_notify"]=> bool(true) ["email_single_user"]=> bool(true) ["email_multiple_users"]=> bool(true) ["email_user_groups"]=> bool(true) ["NextGEN Attach Interface"]=> bool(true) ["copy_posts"]=> bool(true) ["ure_edit_roles"]=> bool(false) ["ure_create_roles"]=> bool(false) ["ure_delete_roles"]=> bool(false) ["ure_create_capabilities"]=> bool(false) ["ure_delete_capabilities"]=> bool(false) ["ure_manage_options"]=> bool(false) ["ure_reset_roles"]=> bool(false) ["edit_ads_txt"]=> bool(true) ["manage_feed_settings"]=> bool(true) ["edit_feed_source"]=> bool(true) ["read_feed_source"]=> bool(true) ["delete_feed_source"]=> bool(true) ["edit_feed_sources"]=> bool(true) ["edit_others_feed_sources"]=> bool(true) ["publish_feed_sources"]=> bool(true) ["read_private_feed_sources"]=> bool(true) ["delete_feed_sources"]=> bool(true) ["delete_private_feed_sources"]=> bool(true) ["delete_published_feed_sources"]=> bool(true) ["delete_others_feed_sources"]=> bool(true) ["edit_private_feed_sources"]=> bool(true) ["edit_published_feed_sources"]=> bool(true) ["manage_feed_source_terms"]=> bool(true) ["edit_feed_source_terms"]=> bool(true) ["delete_feed_source_terms"]=> bool(true) ["assign_feed_source_terms"]=> bool(true) ["edit_feed_item"]=> bool(true) ["read_feed_item"]=> bool(true) ["delete_feed_item"]=> bool(true) ["edit_feed_items"]=> bool(true) ["edit_others_feed_items"]=> bool(true) ["publish_feed_items"]=> bool(true) ["read_private_feed_items"]=> bool(true) ["delete_feed_items"]=> bool(true) ["delete_private_feed_items"]=> bool(true) ["delete_published_feed_items"]=> bool(true) ["delete_others_feed_items"]=> bool(true) ["edit_private_feed_items"]=> bool(true) ["edit_published_feed_items"]=> bool(true) ["manage_feed_item_terms"]=> bool(true) ["edit_feed_item_terms"]=> bool(true) ["delete_feed_item_terms"]=> bool(true) ["assign_feed_item_terms"]=> bool(true) ["edit_feed_blacklist"]=> bool(true) ["read_feed_blacklist"]=> bool(true) ["delete_feed_blacklist"]=> bool(true) ["edit_feed_blacklists"]=> bool(true) ["edit_others_feed_blacklists"]=> bool(true) ["publish_feed_blacklists"]=> bool(true) ["read_private_feed_blacklists"]=> bool(true) ["delete_feed_blacklists"]=> bool(true) ["delete_private_feed_blacklists"]=> bool(true) ["delete_published_feed_blacklists"]=> bool(true) ["delete_others_feed_blacklists"]=> bool(true) ["edit_private_feed_blacklists"]=> bool(true) ["edit_published_feed_blacklists"]=> bool(true) ["manage_feed_blacklist_terms"]=> bool(true) ["edit_feed_blacklist_terms"]=> bool(true) ["delete_feed_blacklist_terms"]=> bool(true) ["assign_feed_blacklist_terms"]=> bool(true) ["edit_feed_template"]=> bool(true) ["read_feed_template"]=> bool(true) ["delete_feed_template"]=> bool(true) ["edit_feed_templates"]=> bool(true) ["edit_others_feed_templates"]=> bool(true) ["publish_feed_templates"]=> bool(true) ["read_private_feed_templates"]=> bool(true) ["delete_feed_templates"]=> bool(true) ["delete_private_feed_templates"]=> bool(true) ["delete_published_feed_templates"]=> bool(true) ["delete_others_feed_templates"]=> bool(true) ["edit_private_feed_templates"]=> bool(true) ["edit_published_feed_templates"]=> bool(true) ["manage_feed_template_terms"]=> bool(true) ["edit_feed_template_terms"]=> bool(true) ["delete_feed_template_terms"]=> bool(true) ["assign_feed_template_terms"]=> bool(true) ["edit_shortcoder"]=> bool(true) ["read_shortcoder"]=> bool(true) ["delete_shortcoder"]=> bool(true) ["edit_shortcoders"]=> bool(true) ["edit_others_shortcoders"]=> bool(true) ["publish_shortcoders"]=> bool(true) ["delete_shortcoders"]=> bool(true) ["delete_published_shortcoders"]=> bool(true) ["delete_others_shortcoders"]=> bool(true) ["edit_published_shortcoders"]=> bool(true) ["aioseo_manage_seo"]=> bool(true) ["aioseo_page_analysis"]=> bool(true) ["aioseo_page_general_settings"]=> bool(true) ["aioseo_page_advanced_settings"]=> bool(true) ["aioseo_page_schema_settings"]=> bool(true) ["aioseo_page_social_settings"]=> bool(true) ["rank_math_edit_htaccess"]=> bool(true) ["rank_math_titles"]=> bool(true) ["rank_math_general"]=> bool(true) ["rank_math_sitemap"]=> bool(true) ["rank_math_404_monitor"]=> bool(true) ["rank_math_link_builder"]=> bool(true) ["rank_math_redirections"]=> bool(true) ["rank_math_role_manager"]=> bool(true) ["rank_math_search_console"]=> bool(true) ["rank_math_site_analysis"]=> bool(true) ["rank_math_onpage_analysis"]=> bool(true) ["rank_math_onpage_general"]=> bool(true) ["rank_math_onpage_advanced"]=> bool(true) ["rank_math_onpage_snippet"]=> bool(true) ["rank_math_onpage_social"]=> bool(true) ["rank_math_admin_bar"]=> bool(true) ["rank_math_analytics"]=> bool(true) ["rank_math_content_ai"]=> bool(true) ["srm_manage_redirects"]=> bool(true) ["SPF Manage Analytics"]=> bool(false) ["administrator"]=> bool(true) ["editor"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
Floors are always last. Nonetheless, the painters should still cover them with drop cloths when they paint. I have not had the problem of floor dust sticking to the walls. If you are concerned, you can ask the floor folks to vacuum horizontal surfaces such as shelves. Most cleaning companies also offer post-construction cleaning. It is slightly more expensive than regular cleaning (usually about $20 more per hour).
curated | 11 years and 2 months ago
string(1) "1" object(WP_User)#5153 (8) { ["data"]=> object(stdClass)#5154 (12) { ["ID"]=> string(6) "176931" ["user_login"]=> string(7) "curated" ["user_pass"]=> string(34) "$P$B3bbhAoyexY/WIMX5pYkD7IREIqgjL1" ["user_nicename"]=> string(7) "curated" ["user_email"]=> string(15) "c@curatedny.com" ["user_url"]=> string(22) "/forums/users/curated/" ["user_registered"]=> string(19) "2017-08-10 14:15:50" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(7) "curated" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(176931) ["caps"]=> array(2) { ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(2) { [0]=> string(10) "subscriber" [1]=> string(15) "bbp_participant" } ["allcaps"]=> array(4) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
Floors first. Let them dry and cure and then cover with something heavy duty like Ramboard. http://brownstoner.staging.wpengine.com/curated
resident2 | 11 years and 2 months ago
string(1) "1" object(WP_User)#5147 (8) { ["data"]=> object(stdClass)#5155 (12) { ["ID"]=> string(6) "181002" ["user_login"]=> string(9) "resident2" ["user_pass"]=> string(34) "$P$BYKCrEpDU34.3RJghRPk8/Xp1XpCve/" ["user_nicename"]=> string(9) "resident2" ["user_email"]=> string(21) "Jamanda1255@Yahoo.com" ["user_url"]=> string(0) "" ["user_registered"]=> string(19) "2017-08-10 14:07:33" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(9) "resident2" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(181002) ["caps"]=> array(1) { ["bbp_participant"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(1) { [0]=> string(15) "bbp_participant" } ["allcaps"]=> array(1) { ["bbp_participant"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
I always insist on floors first. Cover with 2-3 cross wise layers of construction paper with masking tape to the edges and corners to protect the floors and then plaster and paint. You end up with a much cleaner job and saves on the cleaning and touching up afterwards.
clairebear246 | 11 years and 2 months ago
string(1) "1" object(WP_User)#5151 (8) { ["data"]=> object(stdClass)#5156 (12) { ["ID"]=> string(5) "58691" ["user_login"]=> string(13) "clairebear246" ["user_pass"]=> string(34) "$P$Bfx775nrlqhe2XlnJPO13sKyZZMhY6." ["user_nicename"]=> string(13) "clairebear246" ["user_email"]=> string(24) "claire.howorth@gmail.com" ["user_url"]=> string(28) "/forums/users/clairebear246/" ["user_registered"]=> string(19) "2017-08-10 14:28:54" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(13) "clairebear246" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(58691) ["caps"]=> array(2) { ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(2) { [0]=> string(10) "subscriber" [1]=> string(15) "bbp_participant" } ["allcaps"]=> array(4) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
hahaha. thank you, both. sh*t, i have to trust them though! sigh. we’ll see.
rh | 11 years and 2 months ago
string(1) "1" object(WP_User)#5153 (8) { ["data"]=> object(stdClass)#5157 (12) { ["ID"]=> string(4) "3878" ["user_login"]=> string(2) "rh" ["user_pass"]=> string(34) "$P$BL48JCuNvr9CIMtn9XLzqcR6qYGkGS1" ["user_nicename"]=> string(2) "rh" ["user_email"]=> string(22) "info@reclaimedhome.com" ["user_url"]=> string(27) "https:www.reclaimedhome.com" ["user_registered"]=> string(19) "2017-08-10 14:12:47" ["user_activation_key"]=> string(0) "" ["user_status"]=> string(1) "0" ["display_name"]=> string(2) "rh" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(3878) ["caps"]=> array(2) { ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(2) { [0]=> string(10) "subscriber" [1]=> string(15) "bbp_participant" } ["allcaps"]=> array(4) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
Usual rule of thumb is ‘don’t trust contractors’. I usually do walls first because it saves the time and money of protecting the floors. Be sure to have touch up paint on hand though.
Arkady | 11 years and 2 months ago
string(1) "1" object(WP_User)#5156 (8) { ["data"]=> object(stdClass)#5147 (12) { ["ID"]=> string(5) "14677" ["user_login"]=> string(6) "Arkady" ["user_pass"]=> string(34) "$P$BSLpIhH1FLNbV2Qdpb/F67tu7brrgw1" ["user_nicename"]=> string(6) "Arkady" ["user_email"]=> string(20) "rkdillon@verizon.net" ["user_url"]=> string(21) "/forums/users/arkady/" ["user_registered"]=> string(19) "2008-08-04 21:50:38" ["user_activation_key"]=> string(20) "HL9P1Plx6tnm1l8GiJvd" ["user_status"]=> string(1) "0" ["display_name"]=> string(6) "Arkady" ["spam"]=> string(1) "0" ["deleted"]=> string(1) "0" } ["ID"]=> int(14677) ["caps"]=> array(2) { ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["cap_key"]=> string(15) "wp_capabilities" ["roles"]=> array(2) { [0]=> string(10) "subscriber" [1]=> string(15) "bbp_participant" } ["allcaps"]=> array(4) { ["read"]=> bool(true) ["level_0"]=> bool(true) ["subscriber"]=> bool(true) ["bbp_participant"]=> bool(true) } ["filter"]=> NULL ["site_id":"WP_User":private]=> int(1) }
Usual rule of thumb is ‘from the top down’.
