Skylight window need repair/replacement
Hi, I have the original skylight window with broken soldering. You cannot see it from the picture, but some of part glass parts look like they will fall down in any moment. What can be done about this window? Can you recommend someone who can reapply the solder to restore strength of the joints? If I have to order new window, where to order a comparable one?
bobjohn
in About Brooklyn 12 years and 1 month ago
Arkady | 12 years and 1 month ago
object(WP_User)#5198 (8) {
  object(stdClass)#5177 (12) {
That’s called a Lay Light & usually they’re easily removed so you could take it to a stained glass studio. I went into my cock loft & just took mine down – it was resting on the frame of the ceiling.
bobjohn | 12 years and 1 month ago
object(WP_User)#5197 (8) {
  object(stdClass)#5196 (12) {
    string(5) "15883"
    string(7) "bobjohn"
    string(7) "bobjohn"
    string(7) "bobjohn"
  int(15883)
here is the picture, but you cannot see the failing joins.
