Professional Engineer or Structural Engineer Needed
I have two 3-family new construction houses in Bed Stuy where there are spaces between the wall and ceiling sheetrock. They are about 10 years old. I am not sure if this is simply bad workmanship, or an issue with the foundations needing reinforcement. Who can you recommend to inspect these to tell me if the foundations need reinforcement or not? How much will the service cost? Thanks for your thoughtful response/s.
slopebob2233
in About Brooklyn 12 years ago
cate | 12 years ago
object(WP_User)#5198 (8) {
  object(stdClass)#5177 (12) {
Did you have the buildings inspected before purchase? They would flag this if it were a problem.
cate | 12 years ago
object(WP_User)#5196 (8) {
  object(stdClass)#5199 (12) {
Have the spaces moved? Usually wall movement will show up as a large diagonal crack across the wall. An engineer will charge about $700 to $900 to do an inspection.
