Obtaining a C of O - Pros and Cons
What are the pros and cons of getting a Certificate of Occupancy? If a building does not have one, should the owner try to get one? If so, why? Is it ever necessary? Would it be advisable under certain circumstances not to get a C of O? Thanks
nintzk86
in About Brooklyn 11 years and 10 months ago
ditmarsman | 11 years and 9 months ago
object(WP_User)#5152 (8) {
  object(stdClass)#5140 (12) {
    string(6) "178669"
    string(10) "ditmarsman"
    string(34) "$P$BG0FuEOxh5X0k.anNV4K5ZgF5ZvLcV0"
    string(21) "DitmarsApts@gmail.com"
    string(52) "http://bstoner.wpengine.com/forums/users/ditmarsman/"
  int(178669)
You can also see if HPD has i-cards for your building, that is the equivalent if you can’t find a CofO
BobMarvin | 11 years and 10 months ago
object(WP_User)#5151 (8) {
  object(stdClass)#5150 (12) {
FWIW I obtained a mortgage without a CofO as, I’m sure have many other Brownstoner readers,
patrick | 11 years and 10 months ago
object(WP_User)#5153 (8) {
  object(stdClass)#5154 (12) {
    string(5) "77110"
    string(7) "patrick"
    string(7) "patrick"
    string(22) "patrickguidotti@me.com"
    string(19) "2010-09-30 15:28:10"
    string(7) "patrick"
  int(77110)
From a mortgage perspective, you should get the C of O if you intend to ever obtain financing for the property. Even if you have no immediate need for a mortgage, if you intend to sell the property to a buyer who will need to obtain financing, eventually the C of O will be necessary.
Augustiner | 11 years and 10 months ago
object(WP_User)#5147 (8) {
  object(stdClass)#5155 (12) {
If you are talking about buying a house without C of O, please check if it´s an SRO. A house can have no C of O but still be an SRO. Enter the address on http://www.nyc.gov/html/hpd/html/home/home.shtml , and if the number of “B” units shows anything but “0”, you´re in for trouble. Other than that, if you plan to do a major renovation it´s hard to avoid the C of O route. It is generally recommendable not to apply for a C of O, if you don´t have a specific reason.
dazednconfused2 | 11 years and 10 months ago
  object(stdClass)#5156 (12) {
    string(6) "209624"
    string(15) "dazednconfused2"
    string(34) "$P$BghKLTB3pwiNsI5BhQ/fSb/bBQWxiL0"
  int(209624)
From an architect and DOB standpoint, they are only required when you do a renovation changing the use, occupancy or egress, or when adding a floor or more. For instance, if you’re a one- or two-family and you change to a three-family or more, or if you go the other way, you’ll get a new C of O as part of the renovation. The prevailing opinion is typically that there’s no need to get one unless there’s a specific need for it. In general, you’re perfectly fine without one.
daveinbedstuy | 11 years and 10 months ago
  object(stdClass)#5157 (12) {
Some but not many.
Arkady | 11 years and 10 months ago
  object(stdClass)#5158 (12) {
Some insurance companies insist on them.
