New gas Stove
I was wondering is my gas pipe was up to date in NYC code . I’m in the process to install a new gas stove for my rental apt . Thanks
benoit
in About Brooklyn 10 years and 3 months ago
benoit | 10 years and 3 months ago
object(WP_User)#5311 (8) {
  object(stdClass)#5299 (12) {
    string(4) "8749"
    string(6) "benoit"
    string(34) "$P$BTFqoE1CLCi3wc4aH2z819rgYYciWt0"
    string(6) "benoit"
    string(22) "benoitmoeyaert@mac.com"
    string(19) "2017-08-10 14:14:42"
    string(20) "C3g3QKIlgGVb9VKsxC3V"
    string(6) "benoit"
  int(8749)
I’m changing the flexible part. Apparently it have to change every 5 to 10 years, last time that i did change it was about 9 years ago. What he said was i need to have a new gas connection up to code . I text the plumber a picture of the gas valve 3 days and i haven’t received any reply yet . But i’m placing a new flexible part . There is no leak what so ever , i’m updating my renta apartment with a new stainless gas range stove.
neweco | 10 years and 3 months ago
object(WP_User)#5310 (8) {
  object(stdClass)#5309 (12) {
    string(6) "194012"
    string(6) "neweco"
    string(6) "neweco"
  int(194012)
Looks fine to me.
nalusurf | 10 years and 3 months ago
object(WP_User)#5299 (8) {
  object(stdClass)#5306 (12) {
    string(6) "176812"
    string(8) "nalusurf"
  int(176812)
Just to be sure spray a dish detergent/water solution on the connections. If there are no bubbles forming you are good to go. If it bubbles, shut it off!
BobMarvin | 10 years and 3 months ago
  object(stdClass)#5312 (12) {
Even if the flexible part does fit [which is likely]it’s common sense to replace it. Those things are both expendable and fairly cheap.
mozeeatupu | 10 years and 3 months ago
object(WP_User)#5313 (8) {
  object(stdClass)#5314 (12) {
    string(6) "176749"
    string(10) "mozeeatupu"
  int(176749)
Looks fine, but can’t see the end. Like Bob Marvin said, maybe he meant the existing flexible part won’t fit the new stove.
  object(stdClass)#5315 (12) {
Is it possible that the plumber meant that you had to change the flexible connector, rather than the valve in your photo?
daveinbedstuy | 10 years and 3 months ago
  object(stdClass)#5316 (12) {
Typical valve used in tens of thousands of installations. Meets code.
object(WP_User)#5315 (8) {
  object(stdClass)#5313 (12) {
    string(4) "8749"
    string(6) "benoit"
    string(6) "benoit"
    string(6) "benoit"
  int(8749)
My plumber told me event without to see the pipe over the phone that I have to change it . I was wondering if he wasn’t taking me for a free ride . I mean not free .
GreenThinker | 10 years and 3 months ago
  object(stdClass)#5317 (12) {
    string(5) "98498"
    string(12) "GreenThinker"
    string(12) "greenthinker"
  int(98498)
Looks good, just like any other gas pipe connection.
