Mystery pipe
Several houses on my block have a U-shaped pipe in the front area. The down-facing end is a few inches above the paver level & is open. The pipe goes through the ground &, as one neighbor of mine put it, “In the cellar we see the pipe entering the building next to the coal chute and dropping directly into the flooring, never to be seen again. The only apparent purpose is to provide amazement to the people, and a sense of the mystery of all things.” Any ideas what it could be?
Arkady
in About Brooklyn 11 years and 9 months ago
cate | 11 years and 9 months ago
object(WP_User)#5208 (8) {
  object(stdClass)#5196 (12) {
That stuck rat must have been quite a sight.
housepoor | 11 years and 9 months ago
object(WP_User)#5206 (8) {
  object(stdClass)#5209 (12) {
    string(5) "71781"
    string(9) "housepoor"
  int(71781)
We have the same thing just outside the entrance below our stoop. We once had a rat crawl out of it, to get stuck at the very end. A mesh screen held with an adjustable metal ring stopped that from happening again. It might be worth considering…
Arkady | 11 years and 9 months ago
object(WP_User)#5207 (8) {
  object(stdClass)#5210 (12) {
Fascinating stuff. Thanks for your responses.
dorkofwindsor | 11 years and 9 months ago
  object(stdClass)#5211 (12) {
everyone is correct. the pipe out front (sometimes it is under the stoop, sometimes in the front yard) is a vent for your plumbing. You will have at least one soil stack vent to the roof, and one out front. What this does is enable neutral pressure in the system, so when things come and go that the system does not encounter suction – and not only enables everything to flow freely – but more importantly it enables the traps to always hold water. Water in your traps – whether it be the trap in your sink or the main trap in your home, is the only thing between sewer gasses and your nose. Pretty important indeed!
object(WP_User)#5210 (8) {
  object(stdClass)#5206 (12) {
Fresh air intake vent.
thetinkerswagon | 11 years and 9 months ago
  object(stdClass)#5212 (12) {
    string(5) "21531"
    string(15) "thetinkerswagon"
  int(21531)
vent or overflow. in the event the sewer line to the street clogs, the stuff will flow out through that pipe before backing up into the house.
gtinsouthslope | 11 years and 9 months ago
object(WP_User)#5219 (8) {
  object(stdClass)#5218 (12) {
    string(5) "42358"
    string(14) "gtinsouthslope"
    string(34) "$P$BLpPq7vBP.E7A/P.n5q/xN5MY4zN91."
    string(18) "dhkosoff@gmail.com"
    string(19) "2017-08-10 13:46:19"
  int(42358)
It’s a sewer vent pipe. When my home was inspected before purchase, the inspector suggested I add add one if I ever fixed my sewer line in the future. The pipe is turned down so the sewer fumes aren’t pointed at your window, at least thats what I think.
