Is a legal 2-family brownstone/townhouse required to have a sprinkler system?
It’s a legal 2-family, listed as 3 stories with a garden level. No commercial use. Any insight would be much appreciated!
nyflicka
in About Brooklyn 12 years and 1 month ago
nyflicka | 12 years and 1 month ago
object(WP_User)#5182 (8) {
object(stdClass)#5137 (12) {
string(4) "1421"
string(8) "nyflicka"
string(34) "$P$B2YjJ8zWFyg.7pxXkts90LaQjtpIaK."
string(21) "nyflicka1@hotmail.com"
string(18) "/forums/users/mmm/"
string(19) "2017-08-10 14:11:45"
int(1421)
Thanks for all of that. So it seems that unless you are changing the C of O it is not a necessity.
dazednconfused2 | 12 years and 1 month ago
object(WP_User)#5181 (8) {
object(stdClass)#5180 (12) {
string(6) "209624"
string(15) "dazednconfused2"
string(34) "$P$BghKLTB3pwiNsI5BhQ/fSb/bBQWxiL0"
int(209624)
As housepoor mentioned, you may be required to add sprinklers if you’re changing the number of families. However, to elaborate, going from 2 to 1 will not require sprinklers as they are both the same use group. Going from 2 to 3 will, as will going from 3 to 2 in most cases, because that’s changing use group.
housepoor | 12 years and 1 month ago
object(WP_User)#5137 (8) {
object(stdClass)#5177 (12) {
string(5) "71781"
string(9) "housepoor"
int(71781)
If you are looking to change use — including going down in units — you may be asked to install a full house sprinkler system. I proposed a change from a 3 to a 2 family (and in the process add a penthouse) and was told the existing hallway sprinklers were not adequate and I needed to sprinkler the whole house. It killed the idea.
object(stdClass)#5183 (12) {
string(4) "1421"
int(1421)
Thanks for that. Would love to hear any additional responses.
bedstuy06 | 12 years and 1 month ago
object(stdClass)#5184 (12) {
string(6) "176900"
string(9) "bedstuy06"
string(34) "$P$BOcfhzYrfJTvL0QLV4mfGMpAAQEqiB/"
string(28) "jenniferseiber@earthlink.net"
string(24) "/forums/users/bedstuy06/"
int(176900)
I believe 3 family or more requires a sprinkler system and fire escape. A two family should be exempt. Maybe someone else will reply to confirm.
