Brownstone stoop and under stoop repair
Looking to meet with several masons/brownstone specialists to have my stoop and under stoop area repaired. Based on my research on Brownstoner I’ve narrowed the list down to the following companies/individuals: Excellent Contracting (Meraz) Taz aahmodiyahi@gmail.com Glenford 347.641.5283 HiTech Construction- 718-693-3537 CTG Construction-Milad 718-669-8305 Anyone have any bad experiences with any of these? Any one else I should add to my list? Thanks
hannah24
in About Brooklyn 11 years and 7 months ago
mrfox | 11 years and 7 months ago
object(WP_User)#5208 (8) {
object(stdClass)#5196 (12) {
string(5) "43966"
string(5) "mrfox"
string(34) "$P$B42BLXjW7RUEVJAGr9.cGx8WEa8Cl2."
string(5) "mrfox"
string(18) "mattpoor@gmail.com"
string(20) "/forums/users/mrfox/"
string(19) "2017-08-10 13:34:07"
string(5) "mrfox"
int(43966)
I recommend Excellent Contracting without hesitation. Meraz did a complete repair of the stucco on the rear and side walls of our 4 story brownstone (was applied originally by the developer we purchased from). We got 5 quotes in total, all from companies that can be found in these forums. Excellent gave us the longest warrantee on the work and also carry the highest liability insurance of any of the companies we contacted. Not the cheapest and not the most expensive. Work was done exactly as it should be, in the timeframe quoted to us.
sjb | 11 years and 7 months ago
object(WP_User)#5207 (8) {
object(stdClass)#5206 (12) {
string(4) "3774"
string(3) "sjb"
string(34) "$P$BoIwLEwNIfHO23LKtTiS5pOAf0GvoA1"
string(3) "sjb"
string(18) "sjbinkov@gmail.com"
string(18) "/forums/users/sjb/"
string(3) "sjb"
int(3774)
I also would not use CTG again. Millad promises the world and then does not fulfill his promises. My stoop also deteriorated and two times he had to repair after many many calls to him.
brooklynchic | 11 years and 7 months ago
object(WP_User)#5203 (8) {
object(stdClass)#5209 (12) {
string(6) "178192"
string(12) "brooklynchic"
string(34) "$P$Bd.CO.UA7P3124wL7OWWmBeJQydSJa."
string(16) "kimcaton@msn.com"
string(27) "/forums/users/brooklynchic/"
string(19) "2017-08-10 14:21:46"
int(178192)
BEWARE! I would advise against using CTG Construction. Millad and his crew did my stoop for me around September of 2012 and it has already started to deteriorate. There are also three other stoops he did that same year up the street from me that are deteriorating as well.
hannah24 | 11 years and 7 months ago
object(stdClass)#5210 (12) {
string(6) "180574"
string(8) "hannah24"
string(34) "$P$BQHINz1oa0cIbWCCEQ72lGlb.w9KEL."
string(23) "beatrizm12484@gmail.com"
string(19) "2017-08-10 14:06:32"
string(20) "BMIn896HRuzaz2xmdtU1"
int(180574)
Thanks Daveinbedstuy…I’ve seen the mortar mix skim coat on two of my neighbors under stoop areas. Is it ok to do that over brick or is it best (if possible) to leave the brick exposed?
object(stdClass)#5211 (12) {
string(6) "180574"
int(180574)
Thanks everyone. And yes, got Glenford’s name from your post. I’m in Bed Stuy as well so figured I should use someone the local’s recommend. My e-mail is beatrizbmelendez@gmail.com Would love to come by and see his work, thanks for offering!
daveinbedstuy | 11 years and 7 months ago
object(WP_User)#5210 (8) {
object(stdClass)#5203 (12) {
Milad did a nice job with mine. Too bad this site can’t resize the files so I can post the before and after pics. Under the stoop he basically skim coated it with a mortar mix. I wan’t too particular on how it looked.
bedstuytownhouse | 11 years and 7 months ago
object(WP_User)#5211 (8) {
object(stdClass)#5208 (12) {
string(4) "5144"
string(16) "bedstuytownhouse"
string(34) "$P$BBnz.Fab/ro0nVxPBVpsVEAzT.g3Gs0"
string(26) "andreaetienne228@yahoo.com"
string(31) "/forums/users/bedstuytownhouse/"
string(19) "2007-11-16 03:10:38"
int(5144)
Glenford is the best…you probably added his name to your list based on some of my old posts. You are welcome to swing by to check out his work. Just post your email address we can fix a time if you’d like.
